Mpb is where I get mine
Excellent stuff.
Think this thread name should be changed to "questions for newbies". It's all been helpful sound advice.
I will probably buy the lens in the next month or so.
The body maybe in the next 6 months depending.
If not the 5d what would you recommend? Any tips on buying second hand? Any reliable sources?
E.g. say I found something like this later on in the year. https://www.gumtree.com/p/digital-c...ith-original-box-and-50mm-1.4-lens/1155238535
Dodgy?
Don't forget though that if you want to take pics of wildlife, you're going to have to buy a new lens whatever you decide with the body, unless your subjects are incredibly tame. You can't really take wildlife unless you have a longer reach lens even with a cropped sensor. I suppose you could crop a picture to zoom in....
Yes,but under a limited budget I would throw all the money at a lens. then there is the simple fact that pixel density is fairly critical for wildlife unless you have megabucks for a 600mm f/4.0, and even then you will find professionals reaching to their bag of converters AND putting the lens on a crop body.
A crop body with a 70-300mm lens is a reasonable wildlife kit for larger animals, and is very reasonably priced. Even a cheap FF camera and a 100-400 would be a lot more expensive but not really any better, and potentially worse. Then at the end of the day the only advantage in the FF setup with a much bigger more expensive lens is about 1 stop lower ISO and slightly sharper pixels -important if you are trying to sell wildlife photos for $1200 on a 30x20" canvas but not for mortals.
Hmmmm now thinking of stretching for the Canon EF 70-200mm f/4.0 L USM Lens for £435. Better image quality but the focal length is reduced + no IS.
I can't stretch to the L 70-300 - £900 is a bit much.
OR:
https://www.mpb.com/en-uk/used-equi...non-ef-70-300mm-f-4-5-6-do-is-usm/sku-604371/
The 70-300mm DO IS USM version for £369
I wouldn't get the 70-200 for wildlife, too short.
Just get this:
http://www.camerapricebuster.co.uk/Canon/Canon-EF-lenses/Canon-EF-70-300mm-f4-5.6-IS-USM-Lens
Just get this:
Yeah that seems to be main one I've got my eye on. It's only £290 on amazon. Worth paying an extra £70 for the DO version? (second hand) - its £1k new! - oddly second hand much cheaper than the L version which is £900 new but approx £650 second hand (??)
I think it's only the Canon mkii DOs that are good from what I remember?
I don't think wildlife is one you're gonna be happy cheaping out on. I wasnt. Zoo is fine. But true wildlife.. To get anything you're happy with I'd say 100-400mm canon lens is probably cheapest I'd even consider.
But I'm pretty fussy
What exactly do you mean by wildlife?
If you mean UK birds.. That's gonna be expensive
Of you mean zoo that's not too tough
If you mean bugs (macro) that sits in between.
Probably birds/zoo
Macro would be a huge bonus for insects and general
The pure reason I suggested 70-200 is because the sharpness in the L lens is amazing. With the 550d crop equates to roughly 320mm?
Look at this guy e.g. he uses this lens.https://m.flickr.com/#/photos/steviec-photography/sets/72157628258201743/
Probably birds/zoo
Goldfinch in the Morning by Joel Spencer, on Flickr
