Isn't the whole court process centred around proving that an accusation happened?
Just go to Google and type in 'low speed car flip'. Plenty of videos for you!
just did, stopped after the first 2 as speed was irrelevant (and internet at work is pants) - first car mounted a wall or some other object at an angle causing it to flip, second video another car ran into the rear of another again at an angle and was clearly accelerating (beyond 10 mph).
any chance you could link to a couple of vids where slow moving cars on level, dry surfaces have flipped while turning?
Clearly you missed the bit where I said it collided with the central reservation?
I mean I do understand reading is hard sometimes, dont get me wrong. It normally helps when you're trying to be smart though!
This one is probably less than 10mph - https://www.youtube.com/watch?v=Gm7i_0Z8sLk
oh my such upset at a simple request! actually I didn't miss the bit where you said it collided with the central reservation. but striking a central reservation at ~10mph should in most instances should not cause a car to flip, there simply isn't enough energy. I only asked if you could link some of these videos you speak of, it was a genuine request as the 2 videos I watched were nothing like what you describe happening, both were vehicles 'riding up' quite an incline while accelerating before flipping. not sure where the upset is coming from?!
I mean I do understand you are getting your pants in a twist cause you think no one believes your little story![]()
fyi I neither believe nor disbelieve your tale, I just would genuinely like to see a video similar to your experience to see how it happened.
Its the going sideways from hitting a pothole at 10MPH that was the main issue.![]()
I didn't say that. Someone else said that in reference to my post - incorrectly.
https://www.youtube.com/watch?v=eaH...46NC-w9kW2EHTmcbFRe4qg2F5B12tTLQA1aZgg18JNduw
Low speed. Flips. Granted, it collides with a car and not the central reservation and kerb like the woman I saw did. is that the clip at ~ 9mins? no way she was going at 10mph plus the other cars front tyre and wing act as a ramp
https://www.youtube.com/watch?v=8MBdDZdRcC4
And another, very low impact. again not sure on the speed, the majority of the traffic may possibly be going about 10mph, but the car that flipped was going quite a bit faster - hard to tell to be honest.
https://www.youtube.com/watch?v=sJ2LyYqpTX4
Clips a verge at low speed. - can't get that to load at work for some reason - will look later at home
https://www.youtube.com/watch?v=L0Ffm1FYoXk
Really not going fast though does accelerate. that was one of the ones I already had a look at, initially going very slow - but the vehicle began accelerating and continued to do so
don't see enough in there to convince me (not saying your lying) I just can't see how a car striking a kerb at 10mph could flip.
was the car broadside when it hit (sliding) or did it strike at an angle?
Angle. As I say she was going round a roundabout. Swerved to avoid a pothole.
This meant her arse swung out, she over compensated, hit the kerb with her front passenger wheel which lifted it, back end came round hit the kerb, bounced up, hit central reservation then bam. On her roof.
Dunno if this has been posted http://www.cheddarvalleygazette.co....afely-rescue/story-28809823-detail/story.html
