Hehe no worries. I don't review Iiyama models, sorry.![]()
Out of curiosity, any reason? Do you dislike them in some way or just something else?
None of these gaming monitors are pretty in my opinion.
The ViewSonic should be available at the end of March in Europe.
The iiyama is only 280 Euro right now here, very tempted to try one to be honest.![]()
That's amazing dude, thank you, and yeah what you said should be more than enoughI've just ordered one to test, it will arrive Friday.If I like it I will keep it, otherwise it will be returned.
As I have also owned the G2460PF, I can compare it to that. I am not a display professional, so my eyes will be the judge. However, I don't think it takes much to be better than the G2460PF.
What do you guys want to know? I already figured the following:
- Freesync range (I expect 35-120 Hz)
- Freesync flickering issues
- Corruption during alt-tab?
- Color quality
- Is the lowest brightness usable? (Because G2460PF destroyed my eyes)
More?
So I have used the GB2488HSU-B2 for about an hour now, and these are my findings:
- Freesync range:
35-120 Hz, enabling Freesync in the OSD will disable 144 Hz in Windows. Also no driver needed.
- Freesync flickering issues:
Not present so far.
- Corruption during alt-tab:
No issues so far.
- Color quality:
For TN they are great! The default setting (User RGB: 100/100/100) is a bit too much, but the "Normal" setting is very nice. Much better than AOC G2460PF in my opinion. But keep in mind it still is a TN gaming monitor, so the contrast still is not that great. You should not expect IPS like colors.
Lowest brightness setting is very dim, highest setting is extremely bright. I have it on 50 right now and it is perfect for my eyes.
Some other things:
- I like the design, it's nothing flashy and fits in with the rest of my stuff.
- The OSD is nice, but the touch buttons suck. They are slow and not intuitive. However, I won't return for that...
- Freesync works great, no issues so far.
- Viewing angles are OK, nothing more. Just like you would expect from TN.
- No dead pixels at all, also no noticeable backlight bleed.
So... I will use it more the coming days, but if it keeps running like this I will definitely keep it. It's much much much better than the G2460PF ever was, for not much more money.
Awesome. Thanks again! I'll post my thoughts too when i get it!CS:GO has not given me issues so far. I think this is a winner.![]()
