New SSD
24 Jun 2003
I am thinking on changing the 500gb hard drive in my laptop to a 250 GB ssd , is it possible for me to use some software to make and image of the old drive then transfer it to the new SSD to save me from having to reformat the laptop. the new SSD is smaller than the current installed drive is this possible to do and if so how ?
BTW atm there is only like 100 gb used on the old Hard drive as the laptop is not used for much.
you can use something like Clonezilla, but personally id just backup the appdata folders for the Apps you want to keep (browser/email/etc) and copy them to your fresh install, will be much quicker and a nice clean windows install too.
I would usually do that for a desktop but this is a laptop with auto resume , recovery partition etc.
I used Macrium yesterday and it did a perfect job of cloning my Win7 HDD to a new SSD.
Had a bit of a 'mare getting the ssd to boot to windows though,would only work in IDE mode and had to make some changes in the registry to get AHCI to work.
I had that exact problem today. Apparently if Windows is installed when IDE mode is enabled, it decides to not bother about AHCI and refuses to boot.
Yep. My original install on HDD was in IDE so the cloned install on SSD would not boot in AHCI. I might as well post the sollution I found that worked for me.
1) Run the Registry Editor (regedit.exe)
2) Navigate to Registry Key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Msahci
3) Set the "Start" value to 0 (zero)
4) Navigate to Registry Key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Pciide
5) Set the "Start" value to 0 (zero)
6) Shut down
7) Start up again, but before Windows boots go into the BIOS configuration screens and change the disk mode to "AHCI". Save the new BIOS configuration and restart so that Windows boots.
When Windows starts, it will detect the change, load new disk drivers, and do one more reboot to start up with them.
