Man of Honour
- 5 Jun 2003
- Falling...
the indemnity insurance only covers you for putting right planning and or building regs issues - however if the council makes you pull the extension down, or it falls down on its own it'll do nothing.
The whole 'don't tell the council and they may not check' thing is crazy, the vendor should have know there wasn't any planning / building regs and offered it up front OR made it good - its not too difficult a process IF its been done properly but the fact that they cut corners sticks to high hell so in all honesty your probably better off out of it!
Aren't the SD rizes only with regards to second properties?
That's how I understood it but also how I see it.
