Ok, so group sets. I've currently got tiagra with OEM Shimano brakes and chainset on my better bike, and Claris with Shimano long drop brakes on my rubbish bike. I'm planning on upgrading the better bike to 105 and then shifting the Tiagra to the winter bike and selling the Claris bits. I'm also planning on getting a chainset power meter for my better bike, like the powertap c1, but I can only use 5 bolt cranks with that, so getting the 5800 crankset is pointless. I figure I can save a bit of cash by just buying all the 105 bits bar the chainset, and a tiagra 4600 chainset for the cack bike. Then I can use the OEM crankset with the rest of the 105 kit until I get the power meter and then put the cranks from the OEM unit on the power meter, as that's a 5 bolt set. Then I'll hang on to the OEM chainrings in case I need to swap off the power meter for any reason.
Anyone see any major issues with that plan?
They survived an off that saw the bike bounce through a full 360 though so they are worth the effort.
knee held up fine though.
