- 7 Mar 2016
- Fraserburgh
Hoping that someone has some experience Watercooling a pair of these.
I had a D5 pump, single XSPC CPU Block, 240mm Rad and a dual bay rez. The pump had no problem with the flow, in fact running anything much over 30% seemed a torrent.
Anyway, to cut a long story short. I've added a 2nd radiator to the loop and a pair of Asus Poseidon 980ti's.
What I'm finding is that i'm needing at least 60% PWM on the pump to even start to flow and at 80% PWM I'm seeing around 1.2lpm. I fitted a flow meter to confirm the low flow.
At maximum pump speed I'm seeing 1.8lpm
It looks like the two gpus are a fair restriction on the flow.
Anyone else have experience of water cooling a pair of these, and am I right, I thinking that my loop is too restrictive.
Cheers
Mike
Cheers
Mike
