- 14 Jun 2004
- Newcastle U/T
Rainsport 3s 225 45 18 92Y are under 55 a piece on Catskill if you're ordering a set of 4
they dont feel anywhere near as grippy to me as the rainsports tbhHow many miles have you done on them? Could be tyre sealant or cold outside temperature?Eagle F1's on at the moment and hate themthey dont feel anywhere near as grippy to me as the rainsports tbh
and I really need to keep to similar tread on the wheels due to the AWD system. Car is a Mazda 6mps and I have them at 36Psi. My 2 previous cars were both Mazda 6mps's and had Rainsports on them both.
Any recommendations for a tyre at 215/45/17 for an MX5?
Was going to buy 4 x Rainsport 3's @ £205, but was wondering if stumping up for something like the Yokohama V105s @ £300 was worth the extra cash.
Cheers.
Gibbo holds the V105 in quite high regard.
I found the RainSports pretty good in my MX5 although they didn't wear particularly well I got ~5k out of a set of rears but it's more or less my 2nd car.
Edit: the RainSports had done about 8k on the rear of my previous (FWD) car before going on the MX5
Might just settle with the rainsports then, I did look at the Michelin Supersports @ 400 for a set, but at double the price it seems a bit eccentric.
Got a new tyre as i had a nail in my nearside rear. I have F1 AS2 on my offside rear but the garage has fitted an F1 AS3 to replace the punctured nearside F1 AS2. Only realised when i got home. Should i be concerned or is it fine to mix the two on the same axle? The older F1 AS2 has only 5k miles of wear and it's on a FWD.
