Caporegime
- 18 Oct 2002
Read the Computerbase numbers again. At 1080p a the Fury X is 5% faster than the overclocked 980 where as a 980ti is only 14% faster.
But go up to 4k, the Fury X is 9% faster than a reference 980ti and only 6% slower than a £100 more expensive than it heavily overclocked 980ti and a 980 non ti is absolutely no where near it.
Afaik the computerbase is the worst showing for the Fury X and yet it still beats the 980ti at 4k by close to 10%. Other places show significantly.
At 4k the Fury X is killing it hard.
Minimums would be interesting in more than one review. AMD certainly made some design choices, they went low on rops, high on shaders. So 'easy' scenes they can be top frame rate pumping out limited but minimums they become shader limited and should have higher minimums which is often seen... probably more so as DX12 becomes more prevalent as has already been seen.
the gamegpu results, which you didn't really highlight, showed Fury X ahead of the 980ti at all times. nvidia appears to be winning where it does because people enable an Nvidia optimised shadow option which IMHO doesn't look good(only used it in GTA 5 and wasn't the best option and certainly not IQ improvement worthy of the performance hit taken) and very clearly has a significantly higher hit on AMD than Nvidia.
