Kingston SSD Died ?
15 Mar 2004
Oxford
Hi guys,
I think my Kingston SSD died in the night.
Computer restarted and said a bootmgr error on start up.
My motherboard is not recognizing the SSD now. it was my boot up drive. i have tried another HDD with the power cable and sata cable and tht works fine.
Any ideas ?
James
does it work if you connect it as a slave drive on another computer?
check if there is any firmware updates for it if you manage to get it working.
I know a HDD works but for the sake of it try another sata cable and different port on the mobo, leave it powered down for a bit and see if this helps
Leave it connected to power but not to data for 24 hours then try it again,I know that was a fix for Crucial a while ago,could apply to your drive too.
Kingston recommended me a data recovery place in the us. Prices ranged from $700 upwards lol
Found one in the UK for like £200 just waiting to hear back. Then get a repacent from kingston.
Try hot-plugging, if your motherboard supports it (enable the correct SATA port as hot-pluggable). Could save you £200. I did it recently with an SSD that my mobo wouldn't read.
i think mechanicals tended towards worning signs and broke but still some function, while ssd's tend towards work or just total failure :(
also deleted stuff really seems to be gone with ssds, but mechanical youve got a chance to get stuff back
Got a quote back, £575 inc VAT.
Told them to return the drive lol. I'll just get a replacement. I only rly wanted the pictures but i think most are on facebook anyway.
http://www.macrium.com/Download.aspx?type=home
^for full system images.
Code:
robocopy /e "c:\source folder" "x:\backup\destination folder"
^Save that as 'backup script.bat', then run the bat file by double clicking on it.
First time it runs, it will copy all files/folders, each time after that, it will only copy new/updated files/folders.
