so i decided to install my 2 remaining 980ti's as i got a better cpu with more lanes 5930k
I realise that i have to take out my sound card my wifi card disconnect usb3 and usb2 cables, all the front panel cables i.e power switch hhd lights ect, remove the OC panel connector
phew, all that shiz just to install a 4th card, so i do it and then i install all 4 cards, 2 of them asus and 2 msi golden editions
I then realise that my 1300 WATT !! power supply does not have extra cables, its more than enough to power 4 way sli, my current 2 cards is connected with 2x 8 pin cables
the other spare cables i have is 1 8 pin and 1 6 pin, so im 2 pins down from making full connection, i then try to connect it with 1 6 pin and 1 8 pin, which i do.
but then my 4 way sli bridge does not work because the msi and asus cards are a different height, 2 inches to be precise
so a lack of power and a sli bridge not good, so i decide **** it, i'll just stick with 2 way
what a waste cpu that I bought unnecessarily
so I pull out card 4, i then pull out card 3, but its a bit stiff, I firmly hold it with my index fingers under the fan blades, i pull it out, but i hear a snapp clip noise
I realise that one of the fan blades has snapped off and now it does not spin
so fully re-place everything but 1 fan out of 3, the middle one is not spinning, the temps seem ok for now but is there a way to fix it my self? I see 4 small screws on the fan under the plastic housing...
what a lame scenario, all because i wanted to experience 4 way sli, im gonna sell of 2 and stick with 2 way now, i didnt know it will be such a mission...
