What app is that?
The app is Road Trip. I use it too and its great for keeping track of car costs.
What app is that?
Is it a passive system or one with actual pressure sensors?
If its passive, it just uses the speed sensors to detect difference in rotational speed - you're supposed to reset them at a standstill after you top them up, change tyres etc but people often forget to do that, which triggers the warning.
Is it not on Android? Or am I just crap at searching?![]()
Quick question.
ELM327 Bluetooth or wifi, which is more reliable?
If I have Bluetooth I'm assuming I can't use Bluetooth for music to head unit at same time?
Depends on the phone
If it's android then Bluetooth is simpler, you can use wifi but need to root the phone. Elm327 Bluetooth plus Torque just works and is awesome
For iOS you want a wifi one, some apps claim to work with Bluetooth ones but I've never been able to get them to work and I've never found anyone who has!
1200 miles or so later, oil under it again...
I'm still hunting a leak too, and my attempted fix at the weekend doesn't seem to have solved it!1200 miles or so later, oil under it again...
What was the cause last time?
I think I will do my pads and discs next time too. Never really thought about DIYing those types of things due to not want to get my hands dirty![]()
replaced the front rotars on the E39.
first time i have ever done a job like that before, it was very satisfying not paying for the job to be done.
