Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
***Edit*** I am a idiot!! It's Mayhems X1 that I have not XT1. I only discovered that when digging out the 5ltr container while replying to the support ticket!!
Hi all, I have a problem that keeps happening over and over again and it's only since I started using Mayhem's X1 pre-mix. Basically my blocks keep clogging with a blueish gunk. It started just over a year ago. I took the opportunity to change my fluid as I was swapping my cpu block. I thought I would give everything a thorough clean so bought the Mayhem's Blitz Pro kit and a 5 litre drum of clear XT1 pre-mix direct from Mayhems. After following the instructions I gave everything a good few flushes and then stripped the blocks down to clean between the fins. Once done all the tubing was replaced with PrimoChill PrimoFlex Advanced LRT 7/16" clear tubing and the system refilled with X1.
A couple of weeks later I noticed a build up of gunk on the cpu block (clear plexi top) so I drained it all down again, stripped the blocks and cleaned them, flushed the loop a couple of times, flushed both rads with a vinegar/warm distilled water mix a few times before flushing with distilled water and reassembling the loop.
All was fine for a couple of months when the same thing happened. This time I bought another Blitz Pro kit, cleaned the loop, replaced the Primochill tubing with more of the same and refilled the loop with X1.
All was good for a few more months but the same thing happened yet again. Everything stripped down yet again and cleaned, rads flushed with vinegar mix again and then flushed with distilled water and loop refilled with X1 again.
Not even 4 weeks on and my cpu block is full of gunk again!! I am sick and fed up with this happening and not only is it time consuming but it's also getting expensive. This has only happened since using Mayhems XT1. It does have a blueish tinge to it and before that I was going for up to 2.5 years with no problems with de-ionised water and Primochill Liquid Utopia. Unfortunately you can't get Liquid Utopia any longer which is why I switched to XT1 in the first place. This weekend I will have to strip everything down yet again and when I refill I shall be going back to deionised water. I just need to find a additive to go in it that is as good as Liquid Utopia was.
Has anybody else had similar issues with X1?
Using soft tubing you'll always be better off sticking with water + biocide, if what I've been told over the last couple of months is true
