OP picks least expensive Nano but then a £575 980ti...
Im out . You can smell the bias from miles away.
None of the above.
Of course none of the above.Why would anyone buy less than a Titan X/Fury x these days.They must be poor and of lower class.What was I thinking.
I'd go for the 970 with all those freebies along with a 1080 gsync monitor.
Remove the freebies and I'd get a 390 with equivalent free sync monitor.
This thread is pretty stupid but your comments are even more so.
It's only a £10 difference between the cheapest and most expensive nano (not including water cooled versions) Because all Nano's are the same.
Whereas with the 980Ti, he picked a price smack bang in the middle of the cheapest and most expensive. Which is probably the fairest way to pick as all 980Ti's are not the same, they have different clock speeds and coolers.
What makes your comments even worse is that even if he picked the cheapest 980Ti, the Nano+freesync option would still be cheaper.
Maybe the Bias you smell is your own?
Ha, dont be so naive. OP is pretty much trolling with this thread and it will only end one way (ie closed)
Also the cheapest 980ti would be cheaper and would surely be a fairer comparison as it has a reference cooler and reference clocks like the nano![]()
I would get the 980ti if I was rich enough,but I'm not hence the poor setup I have now lol![]()
It doesn't matter what you use, so long as you enjoy your gaming.![]()
So your saying nano on a cheap monitor is not as good as a 980Ti. Come on man get real.
So you would not buy a nano but a 980Ti would be more to your liking.
20 to 60 FPS LOl so get of your high horse and just stop with the BS.
Here is a test I did in a few games with only 4xMSAA at 1920x1080. with 980Ti card overclocked high.On a cheap monitor.
