- 14 Dec 2013
Changing discs and pads is a piece of **** even for a dumbass like me. Good jack and some basic tools and you can do all four corners in no time.
Presuming theres no problem to fix thats true enough, changing the fluid can be more fiddly
Yep, just make sure you use the correct tools for the job so you don't strip any bolts or hex heads and have to take the car to get the bolts removed anyway, like someone I know but who totally wasn't me![]()
Oil leaks dont tend to affect how well a car runs or sounds until its much, much too late
Have they modified it anymore?
Guess the rust will be the sills
