The Division. Are we interested?
Status
Not open for further replies.
Any tips? I'm lvl 18 and about to start into the DZ. Most of my gear isn't great, is it better to buy, upgrade or just grind and hope you pick it up?
doesn't matter what method. You'll burn through any gear you have very quickly any way as you rank up. Biggest tip I can give is not to sell anything and dismantle everything. You'll need the materials later on when you get to max rank,
I spammed out a bunch of friend invites to people i recognised or played with before in GTA. Apologies if unwanted, just ignore if so!
Good lord, just did todays challenging mission with 3 randomers. I was there with the worst gear and was carrying everyone. 45 minutes I'll never get back :(
Yep, me and trix did Russian Consulate challenge daily today and jesus was it hard. We had a couple of randoms with us where one just leroyed constantly, the other one was ok but eventually had to go afk so we had to replace him. We eventually managed to battle to the rear courtyard and then most of us got DC'd. We then got two new randoms and had to guide them to us via the mobile cover door glitch and back to the end boss. With the amount of time it took us to do it we could have made hundreds of PC's by farming hutch.
Good fun tonight :D
- spamming epic soundboard tracks when you got 1-2 groups extracting = many lols
- 3 solid pink skins!!!!
- 300 phoenix credits
- and had a run where EVERY division tech box that I knew of hadn't been opened so now got about 20 gold division tech iirc
EDIT:
BTW, when you change your firearms etc. check your old guns as it may actually be better than what you have had equipped a few days/weeks ago i.e. my vector is now better than my mp5 navy, I've read that if you have over 2800 firearms, the AUG is the then the best SMG.
Good fun tonight :D
EDIT:
The phoenix credits, did you get them just by doing the missions on challenging? I really need to get some more for the higher end blueprints!
uPlay name: BaDBoY_uK
Add me. I'm up for it ;)
Added, may as well try and make the most of it before they patch it :)
Same here, just doing dailies and named enemies I only made 70 phoenix coins last night.
Only 7 more though and I can finally get my yellow vector :)
Hmm how does that work? shouldnt firearms boost all guns?
While I remember what talents/stats do you have on the mp5? wondering if they roll randomly too, my talents on mp5 are rubbish, & I dont think it has a high roll on damage/rpm either, the larger clip size does help against shotgunners tho, not needing to reload before they drop.
Firearms is a percentage damage increase on the base damage isn't it? Presumably it'll improve higher base damage guns more than lower?
I've hit 30! And now I feel lost! Tried the russian consulat. And got smashed! Currently doing 50k dps with M4 but i just die so quick!!! I need high end gear any ideas?
Solo' the Dark Zone last night for a few hours, just trying to level up my DZ lvl although got killed by a few random players, even when I didn't have any loot what's the point lol
Status
