Hi Guys..
Just bought myself a G-sync monitor after using one over the weekend and being blown away..
Got a quick question.. What happens if the FPS goes over the refresh of the monitor? for instance the monitor i am getting is based at 144Hz and i know most modern games will not hit this high but what happens with older games (CS:GO) where i can easily hit over 200fps.. does G-sync simply turn off and you would get tearing again?
I know you should keep v-sync off in game but something like CS:GO has a console command to limit max FPS so is it a good idea to limit it to the max refresh so g-sync stays on?
