- 18 May 2010
- London
Off topic slightly, but is the use of HBM in the new Nvidia cards gonna mean the same form factor as the Nano?
I bought this one some time ago to replace Corsair's own fan on Hydro H50 liquid cooler. It is very quiet -> https://www.overclockers.co.uk/nois...pro-fan-plps-120mm-pwm-1500rpm-fg-032-nb.html
You'll need at least 1500rpm to keep it at or under 80°C
Wow, that's quite loud for a 120mm fan. How fast does the stock fan on one of these run? I though they were supposed to be quiet...
I'd say water cooling is deffo the way to go for high clocks, AIO if/when it becomes available,
I personally don't think you'll need any fan that'll idle at 1500rpm meself, I reckon a 120mm fan running at,say, 1000-1200rpm would shift about the same amount of air as the 92mm jobbie on the Nano, maybe more, depends how good it is at idle.![]()
'Overclockers Dream'
The stock fan ranges between 1500rpm and 3000rpm, idle speeds of 1500rpm is the lowest speed within the PWM range of the fan. Typical fan speeds under load are around 2500rpm which isn't quiet, but isn't that loud either.
Not at idle, but you'll need 1500rpm + to keep it under 80°C. I've tested with single and dual 92mm fans, and with a single 120mm fan, both just manage to keep it at 80°C with the fans at 1600rpm (92mm) and 1500rpm (120mm).
The bottleneck is the heatsink.
