i5 3570K @ 4.5GHz
EVGA 980Ti SC+ @ 1500/3954
2612
Locked up at 1520, i've not touched the voltage yet (just set to 100% Power Target). do i start to increase the voltage to get past 1520? (temp is 50c)
. Unfortunately no matter what I tried I couldn't get the benchie cobble stones, etc, to show in the pic.
You have a very good card. My evga classified won't even hold 1500/4000 in games. I suggest testing With Firestrike monitoring core clock to make sure its not throttling back and gaming for sn hour or so. My card was stable in heaven 4 at 1520 with a slight voltage increase but crapped out in firestrike and gaming (Squad greenlight maxed in 1440p)
Tried firestrike at the 1500 mark and it worked fine; need to do some longer tests and sessions in game i guess to see full stability.
I think i might just stick at 1500 as don't really need to go higher apart from benching i guess?![]()
What is the memory clocked at? I found a +500mhz (8000 effective) yields a much higher fps than a bump from 1405 core to 1500 core. Both together is obviously ideal but heat increases a lot and crashes could be related to memory overheating
Edit. Out of interest, what is you Firestrike GPU score? (Standard firestrike, not extreme)
Stand back lads, make sure you're sitting down for this one!
CPU & GPU - Intel x5-z8300 @ stock settings
Chuwi Hi10 tablet (yes, a Chinese-imported tablet and it survived running Heaven without crashing or bursting into flames!)
Genuinely surprised the tablet actually ran the bench, so had to post a score in the thread. Let the mocking commence...
Finally after loads of messing around with converters, I've got a screenie of me Nano overclocked and a heaven run done. Unfortunately no matter what I tried I couldn't get the benchie cobble stones, etc, to show in the pic.
The first pic is at stock while the second shows overclocked.
Hopefully this is the first Nano on the scoreboard.
Vcore: stock
Core: 1075mhz
Vram: 545mhz
Fan: 100%
Nice. I always seem to get the average / lemons. Pay extra for a classified and its worse than an SC, what sort of joke is that. I have already returned the first because it would throttle at 66c all the time.
Knowing a cheaper card clocks better on stock volts is just annoying.
It should be that you pay for what you get, not 'lottery'
I had major issues with this one to start; must have been the drivers or something; couldn't get past 1350 to start with. Now i think (learning atm) that i can't go higher because of the power limit maxing? Guess i'd need a mod bios to get past 110% ?
temps rose from 68 degree on the gpu to 80 which is still acceptable and takes a while to get there and like I said with the increased volts and clock speeds this is fantastic!
