Delicious fresh ATF was today's job.
Box taxes 7l but you only get 4 out when you drain it because the torque converter holds so much. The DIY method is drain - fill - drive, 3 times...so 12l of ATF needed of a peculiar spec which costs £12 a litre! Managed to get 20l (conveniently in 5x4l bottles so I could just tip a whole bottle in each time) for £50 delivered from Germany. No more vibration at a standstill and changes are super smooth now, when you're driving normally you can't feel the changes at all. A time consuming job but well worth it.
Also started doing the headlight polishing thing but got rained off
