Is there a way to choose which updates you want? Whenever I install updates it tries to give me wrong drivers constantly and it messes up everything.
Well the 1511 update came out in November and the tool was last updated in January. Stop being no negative.![]()
edit: Actually, do what you like. I didn't last more than a week on my last attempt of using windows 10. Although I had found a hack to get WMC running and had updates disabled, it just didn't feel right to me and I'm much happier back on 8.1. To think I was all over Vista when that first came out.![]()
That is just an example - as the tool lags behind Windows updates (in that specific case a couple of months) it gives plenty of opportunity for problems and that assumes the author continues to support it and regularly.
Think you are missing my point
Say you've got a problem driver and use that tool to block it but continue to install other Windows updates - at some point one of those updates (usually a bigger update) makes changes that sidestep or reset your blocking of that driver/future versions of that driver only this time it breaks Windows making a right mess - or even a big problem if you can't even boot into Windows with that update - that could have been avoided.
me said:just to be clear, I'm not saying people should use this tool to block certain updates and trust windows won't break it in future. Instead, group policy should be used to disable all automatic installation and all updates you want should be installed manually using this tool.
You might think I'm being negative but I've run into stuff like a fair few times over the years but fortunately in 7, XP, etc. you can take full control over things like driver updates and completely stop Windows from ever trying to install a device driver (unless they changed the OS fundamentally in a future update and rolled out an update that made it like Windows 10 removing all those features).
I assume your equally as vocal towards your power company should a power cut cause your PC to reboot?
Sorry, bit slow to reply!
If I kept getting frequent power cuts I'd absolutely be annoyed at the power company and might contact them; but even if I chose not to go that route it would still easily be my choice to purchase some form of UPS and have control over my setup in that respect...
Nobody is asking Microsoft to disable updates for everybody or anything so extreme, just give users some form of flexibility over when and how the updates are applied. All it would take is a simple option such as:
"How should downloaded updates be installed?
1. Install and reboot automatically
2. Install and reboot on next shutdown
3. Turn on, Install and reboot automatically between the times I specify
4. Ask me if I want to install pending updates each time I shutdown
Job done... People who are happy with MS's default (option 3 I guess?) can happily just leave it alone... people who don't want their machine rebooting without their say-so can select an option they'd prefer
End of July isn't it? I might be wrongAnybody know the date when Microsoft will start charging for Win 10.
