seems there are 3 ways then. Spam the shield when the cover deployed (stand in the middle of the cover), deploy the cover whilst facing the door and touching it so the cover deploys through the door, or run through the mission and leave a shield in the doorway then go restart the mission form the start point.
Were there bodies in the doorway? They seem to interfere with it.Tried the last hour to do the <complete mission, place shield and restart mission> the shield disappears no matter what angle or place I put it.
I'm on most nights but GS is over 161, with the banding now that puts you on a different server
They affect the placing of the cover, if there's a few bodies in the doorway sometimes I cannot place the cover at all. Wait a little while for the bodies to disappear, cover can be placed all over.they not if you doing all correctly,bodies doesn't affect extension,as you can see in pic
What's a good dark zone level to be at once I hit level 30?
(I'm currently dz 14/level 21 so still got a long way to go)
is Velvet_Thunder_ someone on here?
Yep, thats me. thought I'd add a few people from here. Am on most evenings and weekends (or until the wife gives me grief)
anyone claim the Uplay name of Zild_uk? Had friend requests by the dozen loads from them last night, trying to work out who it is.
Do PA mission fully,when you finish boss at the end and clear all npc's,door s will be open,go to doors and place EXTENSION COVER (there are few,dont mix-should be EXTENSION,maybe works with others,but i know 100% that EXTENSION works) like this :
after go outside mission area,press map,choose PA and change difficulty to hard-sart mission,now you can use doors and go inside PA,go to ECHO,activate it (sometimes not working first time),go to computer (security) room,activate it,then finish NPC's,collect loot,rince,repeatits 2min work
