- 30 Mar 2016
- East Lothian
I want to add another 250GB SSD to my set up. Space is not an issue so are there any benefits in going for M2 over the 850 Samsung 2.5 SSD?
Hi heartburnron.
Are you referring to a SATA M.2 SSD or an PCIe M.2 drive? The PCIe will be faster than an M.2 SATA drive. However I think that this would be a bit of an overkill for gaming. Having in mind the only actual noticeable part that the drive has regarding gaming (performance wise) is the shorter loading time when you start the game and all the in-game loading screens go away much faster, a regular SSD should be more than enough.
That's just my opinion. Of course you could go for the fastest option which would be a NVME PCIe drive.
edit: I don't know why I wrote about gaming. I guess for some reason I thought that this has anything to do with your choice. Basically this is still accurate performance wise. The NVMe PCIe M.2 and AHCI PCIe M.2 drives are faster than SATA M.2 drives which are practically the same as a regular SATA drive, but have a different form factor.
Hope that helps.
Boogieman_WD
Usually the m.2 pci drive has it's own little slot somewhere on the board. Assuming your motherboard is the one in your sig it's bottom right (cpu at top) just under the heatsink by the sata sockets
Just check if the mobo mounted socket is limited to 10 Gb/s if it is then a x4 PCIE 3.0 slot will allow the highest speed.
Sometimes it's hard to tell if the NVMe drives I have installed are much faster than the SSDs I had before but occasionally I see something that makes me think "damn that was fast" such as decompressing some large 20GB archives in less than 10 secs.
Ok thanks and can you just plug the drive into the x4 PCIe slot so that it's sticking out rather than flush with the board as per the mounted socket?
Personally, I'd do it to get rid of those annoying SATA cables that can never be tidied away properly.![]()
Ok, so the only place it can be installed is the mounted socket and if the mobo supports it - it will give me the x4 PCIe slot speed without actually plugging it into the physical x4 PCIe slot? Is that the way it works?
You'll have to check the motherboard manual to see if the onboard slot is 10Gb/s or the full 32Gb/s (= x4 PCIE 3.0).
Otherwise you would need an adapter such as the one in the link below which utilises a x4 PCIE 3.0 slot for the full 32 Gb/s speed.
https://www.overclockers.co.uk/asus-hyper-m.2-x4-pci-e-mini-adapter-card-black-pcb-hd-032-as.html
It can depends on several factors such as the number and type of PCIE slots on the mobo and what other cards you are already have plugged in the slots.
