- 29 Sep 2003
- Stoke-on-Trent
Ok cheers, saves me a fiver i guess.
Yes, im that cheap.
Yes, im that cheap.
, which was crazy cus it was heaving in there. I've waited longer than that even when the place is deserted before now (hope i didn't steal someone elses order they were waiting for).
Got it up and running and so far just added the profile from tft central and set the settings in nvidia control panel to 2560x1440 @ 60hz (to stop my card clocking up on desktop) and under "manage 3d setting" - "Global settings" have set :-
Monitor Technology = G-sync
prefered refresh rate = Highest available
vertical sync = on
not touched anything in the monitors osd yet.
am i doing it right? Have been playing the witcher lately (the first one as wanna play through 1+2 before getting 3) and it does seem capped at 144 fps where as before on my 60hz monitor was getting anything upto 400 fps in some small buildings with v-sync off (capped at 60 with it on). Does look a lot smoother aswell, even to my old man eyes.
*edit* although watching 1440p vids on youtube do look a lot smoother at 144hz than at 60hz
, don't bank on the offer being available still on wednesday morning, get in by tuesday night if you're ordering online.Been looking for a new monitor to replace my old 24” Dell Ultrasharp as it is starting to show it age a little now.
I have had my eye on this for a while now and seeing on ‘This week only’ has provoked an interest to buy.
It will be used purely for Gaming but I do some freelance design work on it but colour accuracy isn’t massively important
as I have never had a proper colour calibrated monitor. I usually rely on Pantone books for reference anyway.
My main Concerns are would my current rig struggle to run modern titles with decent quality settings?
(recently upgraded GPU due to my old dying)
Asus Maximus IV Extreme-Z Intel Z68 (Stock BIOS)
Intel Core i7 2600K 3.4 GHZ
Crucial RealSSD M4 128GB SATA (OS)
Crucial MX200 1TB SSD (Steam Folder)
WD 300 GB Velociraptor (storage)
WD 150 GB Raptor (storage)
EVGA GTX 980Ti Superclocked+ ACX 2.0+ 6144MB
Corsair AX1200 CMPSU
8GB (2x4GB)Corsair Dominator DDR3 CMP8GX3M2A1600C9
Benny
also can you not overclock that i7 2600k ?You will be fine mate the 980ti is a perfect card for 1440p imo that is why i have onealso can you not overclock that i7 2600k ?
I just used the boards standard Overclock pr-set, so it is sat at about 4.2
I'm not much of a big an overclocker really. Just squeezing the last bit of life out of it before I upgrade the CPU board etc.
In all honesty I want to upgrade the board and CPU but need to do a bit of research into it.
well a new cpu would no offer a massive performance difference for gaming than what you have now imo unless you use cpu intensive software ect.. the dell is a great monitor and G-sync is really nice to have dont think i could go without it now.How does this compare to the PG278Q? I need another 27" 1440p g-sync and this is over £100 cheaper. Alarm bells are ringing.
