Hi,
I recently bought a BMW 320d E90 2010 efficient dynamics from Arnold Clark. It has done under 27,000 mileage and has had full service history 2 from BMW and one recently in February from Arnold Clark themselves.
The issue i'am having is, when the car is started up from cold and i put it in 1st gear and release the clutch slowly with out any revs it seems to be making a rattling type noise coming from the central gearbox area. You can hear it through out all the gears and when you accelerate you can still hear that rattling noise but it tends to get quite in higher gears and higher revs. it also seems to lessen in noise as the car has been warmed up.
there is not a performance degrade or a slipping clutch issue as i thought it might be the clutch going out as it pulls normally and there is not any service lights indicating a fault. the noise is very annoying and as far as i can tell it has not gotten worse but not better either.
I know clutch chatter is normal but this does not seem normal as again it comes from the gearbox area rather than the engine area. I have given back the car with the raised issue mentioned here and they have heard the the noise when the mechanic came in the car with me and i replicated the noise. it is still under their 60 day warranty and i took out a further 1 year warranty with them(glad i did)
its been with them since Friday and they cant seem to find where exactly the noise is coming from even though it is making the noise still.
I was hoping if any of you guys might have an idea? it seems like a tricky one!
also they have given me a VW UP as a courtesy car and it is in RED!!
