Nope the specs are increased
Original PS4
CPU: 8 Jaguar Cores at 1.6 GHz
GPU: AMD GCN, 18 CUs at 800 MHz
Memory: 8 GB GDDR5, 176 GB/s
NEO
CPU: 8 Jaguar Cores at 2.1 GHz
GPU: Improved AMD GCN, 36 CUs at 911 MHz
Memory: 8 GB GDDR5, 218 GB/s
It does all seem a bit of guess work tbh. It will be interesting when it's announced. Offering improved versions of the same games seems a bad idea if you ask me.
Silly decision by Sony. Either do it properly and make a PS5 that is fully backwards compatible with the PS4 or GTFO. While no-one is 'forcing' people to upgrade to a PS4.5, anyone with the cash who wants the best performance will likely do so anyway. This will cause dissention within the user base.
Agreed, if Neo users get frame rate improvements so play 60fps to the normal 30fps - competitive MP will be an interesting thing...Personally think it is lose/lose for users and even developers. I can't see developers spending time optimising properly for both "profiles". Either they will optimise for the standard PS4, to ensure it works decently across a wider market, or they are going to push the boundary and optimise it for the "Neo", which essentially will lead to market fragmentation.
Multi player games will be interesting, as I would hope they would all have to run under a standard profile (as mixing framerates will cause issues, and different visual qualities can have their own advantages/disadvantages e.g. poor example, but "upgraded" smoke and lighting effects may make it harder to see other players in an FPS).
Until there is an official press release then everything is just speculation - for all we know a leak could be intentional to force a reaction from Microsoft.
I liken the upgrade to when i bought a ps3 slim to replace my original fat, only this time round moar powah.
Don't see the issue, personally.
I don't think these specs aren't high enough for true 4K gaming. They will probably just upscale to 4K from 1080P, even 1440p will be challenging task @ 60fps.
