- 3 Oct 2009
- Wales
Not sure if buying one that's been tracked is a sensible idea but I assume you've taken good care of it so get in touch in September if you've still got it
Ugly? Its gorgeous and has so much presence. I'm with you though, I'd have one over an Impreza any day - or an Evo for that matter.
I would never bother wasting time bringing back headlamp lenses, because once the oem protective layer is polished off, they will dull even faster and scratch easily.
I bought a set of second hand oem lights for the M3, when they arrived, they had some pretty bad scuffing that you could feel with your fingernail so pretty bad.. and of course normal dulling with micro scratches..
SO I contacted the guy I bought them off and agreed to a £30 refund against the pair of lights (there was an even deeper scratch on the other one)..
So I went and bought a £25 Meguars Headlight Repair Plus kit, and after some wet/dry and polish the same area shown above now looks like..
Still some very very minor micro scratches, but they look absolutely pristine!
I will order some of the plastic/rubber end guards which I think are pretty cheap and these will be a nice replacement of my current lights which the passenger side had a few of LEDs die..
Nicely done, I'm going to see if I can rescue my headlight lenses in the same way at some point soon.
What causes the LEDs to die? Have you checked your replacements for dead ones or just fingers crossed until fitted?
I will see how it goes, honestly I don't think the rear lights have any coating on them, hence why they scratched so easily in the first place, but I'll keep an eye on it, they will be protected with oodles of wax/sealant and detailing products.. if they do get a bit dull, the plastx just gently applied by hand is all that is needed, 5 mins max.I'm sure you could just use a type of clear coat to prevent them from dulling down again once treated.
Yeah, having seen your before/after shots in the other thread, I'll be doing that to mine!I would never bother wasting time bringing back headlamp lenses, because once the oem protective layer is polished off, they will dull even faster and scratch easily.
Lenses are fairly cheap and will last many years when replaced with new.
Carly is great, I've been coding the Mrs Mini Countryman with it, so easy!Disabled the mildly annoying flickering of the front LED indicator bulbs. Git tired of people telling me "Why are your lights blinking??" when starting the car![]()
I tried a small section of mine, far too pitted and they also 'burn' on the inside slightly or thats how it looks..The lenses are plastic, you will never get the OE finish back after that point.
