I spent the weekend on this and ended up making it sound worse. Argh, the frustration.
I'm just going to make those tiny tweaks (instead of remixing) and be done with it. Haha.
Sounds like a sweet kick drum. You wanna think about using a sidechain compressor to duck the bass under the kick and it will pop out of the mix once again in all its glory without you having to compromise the tone of the bass or EQ the bejeezus out of the kick.
Heres a tutorial
Overall you have done a pretty good job in that soundcloud if that's your mix. SexyGreyFox's tweaks above should be enough, along with the sidechain. Are you using any maximising mastering effects like Ozone or Kuassa Kratos 2 yet? Make sure you don't mix into these! Get a good mix first then apply them.
