which design of cooler do the 980ti's have? If blower then yes, Deffo having just cool air blowing towards their intake fans. Ideally bothwhich design of cooler do the 980ti's have? If blower then yes, Deffo having just cool air blowing towards their intake fans.
If they are the more "open" twin/triple fan design then it's trickier as hot air is blowing out everywhere. For sure having cold air blowing at then will help but gotta also think what's happening to that heated air. It could just be recirculated in the case
Thanks Twirlywoos do I need vram heat sinks or do they come with the G10?
Andi.
Also find out what EVGA's warranty stance is on removing the heatsink. I know MSI is fine with it not sure what other manufacturers have to say.
here is a link to the compatibility table for the Corsair hydro HG10 N980 Edition.
NVIDIA GeForce GTX 980 Ti
EVGA GeForce GTX 980 Ti ACX 2.0+ 6GB GDDR5 06G-P4-4991
EVGA GeForce GTX 980 Ti Hybrid 6GB GDDR5 06G-P4-1996
EVGA GeForce GTX 980 Ti Hydro Copper 6GB GDDR5 06G-P4-4999
EVGA GeForce GTX 980 Ti Superclocked ACX 2.0+ 6GB GDDR5 06G-P4-4993
EVGA GeForce GTX 980 Ti Superclocked+ ACX 2.0+ 6GB GDDR5 06G-P4-4995
EVGA GeForce GTX 980 Ti Superclocked 6GB GDDR5 06G-P4-4992
EVGA GeForce GTX 980 Ti 6GB GDDR5 06G-P4-4990
Stay away from the corsair ones, I got the hg10 for my 980ti and it's shoddy tbh, it bends the pcb horribly and although I thought temp's were good at first (idle around 30) when putting some proper strain on it I'm getting around 80 degrees on tomb raider & gta. Will be ripping it off when I get a chance
Did you put heat sinks on the vrms and vram?
