Caporegime
- 18 Oct 2002
''The 1080 hits its temperature target by dropping the GPU's clock rate. During a gaming loop, it falls all the way down to its base frequency...although we haven’t seen any partner boards yet, it’s probable that third-party coolers will give enthusiasts access to even more headroom, just as we’ve seen in generations past''
http://www.tomshardware.com/reviews/nvidia-geforce-gtx-1080-pascal,4572-11.html
But that article shows:
Where the default profile seems to take the 1080 into the temperature limit, but with the fan at 100% the temps are kept under 70 degrees.
Those are painful, fan turned way up it's not bad but at stock it doesn't even sustain above the base clock.
We will see, right now its sub 2.1Ghz and throttles to way below that once warmed up.
And...
So it not the temperature.
Until we see good overclocks that also hold them it is what it is... but but but nothing. we don't even know yet if the GPU is capable of running 2.5Ghz.
http://videocardz.com/60151/nvidia-geforce-gtx-1080-tested-with-aftermarket-cooler
It is temp, it wouldn't be power, though temps can increase power, just not that much. You can't run at 2.1Ghz be then be throttled by power and end up down at 1.6Ghz, the tomshardware shows the direct link from temp to power. From stock it drops significantly from 1850Mhz to 1600Mhz on a prolonged run, overclock and whack the fan to 100% and they can hit over 2100Mhz but that still throttles over time due to temp. If it was power then the stock run wouldn't go from 1850-1600Mhz as temps went up.
But stock running with a quiet fan Tom is saying this card doesn't even stick above the base clock for prolonged gaming. Again stock fan setting and it's down to 50Mhz above the base clock within 5 minutes of gaming. Worse than that really is, if a founders edition while running quietly won't do much above the base clock, then the better cooled AIB cards that might end up 400-500Mhz faster sustained while still quite, then they won't be at all cheaper.
