- 9 Jul 2013
Just turned PC on and it's just started upgrading. Can I stop it? I take it I can't turn the PC off?
Why the hell as microsoft just took it upon itself to upgrade.
Alright cheers folks. I'll have to research win10 see how people are finding it. I was completely happy with win7 so I'll give it a try for a few days and roll back if no likey.
Can it be upgraded again if you roll back does anyone know?
Invisible upgrades to an existing Win10 installation is one thing, but to upgrade a Win7 install to Win10 without the user's explicit agreement is very, very cheeky. Who's PC do they think it is anyway? Theirs?That's what they stated they would do with Win 10, it makes sure little 'issues' are fixed in most cases before users find the problem.
Andi.
It isn't invisible, it is downloaded then you get asked to confirm.
"What’s more, the installer for Windows 10 will start once it has been downloading, presenting users with a popup. Users will be able to decline the update, once the installer has started, or prevent the update from being downloaded by manually blocking it in Windows update."
Andi.
