if it was a bomb..whats the point of setting it off over the ocean?
if you want to cause massive damage, you set it off as it flies over a large population centre causing most damage...why wait until you are out over the med near your destination?
My bum is twitching as my missus and daughter is to fly to Dubia in August and well the mind thinks.![]()
They're probably more likely to be executed/imprisoned for breaking one of the archaic laws over there than for their plane to crash tbh...
how ignorant are you!?
Lol what? Not ignorant at all
if so then they found a new way or new bomb material undetected that we are not aware of
Makes you wonder if there was a shuffle of some sort within the **** pit,Because the plane suddenly goes 90 degrees left ,starts to fall then does a hard 360 towards the right then looses altitude again before disappearing.
I mean surely if it had been a bomb it wouldn't have done the above...it would have remained its course as usual then just disappeared from radar.
Equally you're much more likley to survive a car crash
