This.I recently upgraded from a Q6600 GTX 660 8GB system to i7-6700k GTX 660 32GB (I plan on upgrading to a 1070 once available). It was abundantly clear it wasn't my GTX 660 which was holding me back, but the Q6600.
Even though I'm still using the GTX 660 (for now) I'm getting a massive boost in FPS across the board in all games.
I don't think adding a more powerful GPU alone will give much of a boost to your system. You need to do a more system-wide upgrade.
Get a 380X and you can play DX12 games at least.
Ofc if you find a cheap 290/290X second hand, and you have the PSU grab it. It will serve you for a very long time and it will not be cripped by the drivers like the above proposed NV cards.
That are not supported any more or in the case of the 970, after the end of summer.
Not supported any more??? Hummm maybe time for me to upgrade my 770. Still works a treat.
I think buying a second hand Q9550/X5470(or something like that) for a few quid will get you better performance than a new gpu.
I have a GTX 660 and I don't think its good enough anymore, suggest a upgrade thx.
Even 7xx series drivers have stopped been developed.
GeForce 6-series and GeForce 7-series GPUs have moved to legacy support with the
GeForce Release 304 drivers.
