- 19 Feb 2007
So the monitor arrived yesterday - yay
This might be useful for any BenQ XL2730Z owners out there looking to change to the Green team or looking for a comparison (as this was my previous monitor).
Here's the highlights:
- Very impressive looking monitor; an understated yet really attractive look - loving the super thin bezzle
- Great build quality overall - feels premium
- Zero dead / stuck pixels
- Very minor but consistent backlight / even around all edges - definitely no concern here and cannot be seen in real usage
- Super, super smooth - G-Sync is very, very good
- Overdrive on this panel has been implemented very well - it has noticeably less inverse ghosting than the BenQ XL2730Z does
- Image quality is very sharp with the 2560x1440 native resolution
- Not yet seen this 'vertical line inversion' problem at all (and I'd say I'm very observant / fussy with defects like this)
- Not seen and issues with inverse ghosting on black to white (or white to black) transitions - looks fine to me
and now the negative points:
- Gamma.... Gamma, Gamma, Gamma (did I mention Gamma?). This is the one thorn in my side that makes me want to return the monitor. It is well documented about the 1.9 default gamma which makes the panel so washed out and eliminates the benefit of the 8-bit panel.
This can be beautifully corrected with a minor adjustment (+0.80 gamma in NVIDIA control panel or one of the .icc profiles here) to make it look outstanding for a TN panel on the desktop (subjectively better than the BenQ XL2730Z even) but this is inconsistent and (depending on the software involved) will be lost when you load a 3D game up which turns it back to being washed out again.
Unlike the BenQ XL2730Z (which shows outstanding colours for a TN panel), this monitor has no hardware / OSD based gamma correction which means you are always at the mercy of software.
I have tried CPKeeper which sometimes works but other times doesn't (e.g. works in Diablo 3, fails in Planetside 2) which is quite frustrating as you know the monitor is capable of so much more when it becomes washed out.
If only Dell had calibrated the monitor better in the factory (shame on them - they would know better than this!) or given the user hardware / OSD based gamma options, the screen would be near perfect
- Minor niggle - the screen has no carrying handle or extras like a headset hook like the BenQ XL2730Z had (very minor complaint I know)
If anyone can help me consistently solve the gamma problem once and for all then I'm all ears.
I'm concerned, however, that this will be partly down to the NVIDIA drivers - I have been reading a lot of reports that they have not been able to maintain their gamma settings correctly since Windows Vista!
