So... 1.6 and 2.1 are due for release on Thursday, here's a few tips from me for anybody who has been unable to play the beta as there have been a few changes that will affect you...
1) You no longer need a basic/intermediate/advanced discovery scanner to find system bodies, you can head to the nav beacon, drop out of supercruise and target the beacon itself (note, the beacon, not the navigation icon, it shows as white on the scanner and your contacts list), this will update your ship with system data and also give you updated mission locations if relevant.
2) NPC's are now a very different kettle of fish, do not go into combat thinking it will be easy or you will lose ships, be cautious until you get a handle on it and always be ready to disengage and run, it is no longer a sure thing that you will outmatch NPC's.
3) Engineered modules... if you target a ship and get a message pop up about some such discovery or another you can be pretty sure that you target has an engineered module on board, be even more cautious then previously, it may not make a bit of difference, on the other hand it might just be something that will make your life very difficult indeed... the same goes for if you see odd coloured lasers and shields.
4) You'll know if you are being hit with engineered weapons as you'll get odd little icons popping up under your shield readout, as above, they may not make a difference as it will depend on what they are but they can make a big difference, emissive munitions hitting you when you aren't running silent aren't going to change the outcome, but heat injectors will if you are already running hot.
5) Target everything... you'll gain more information that can be used in engineer upgrades simply by scanning ships with engineered modules.
6) Resource extraction sites now exist in ice rings too, don't forget this and exclude them when searching for RES
7) If you are running a lower/mid end machine you will probably find you can turn a few settings back up, there's been some great optimisation.
8) Do NOT attempt to ram skimmers in your ship...
Feel free to ask any questions and I will attempt to answer them, seriously looking forward to this release, I've not touched live since beta launched and live feels really sterile in comparison
