There was talk of him having a brake problem.
Ricciardo was royally screwed. He was called to the pits by the team, only for them to not be ready? Inexcusable!
Perez on his out from the pit was all over the yellow line, and I am sure he actually crossed it. That's a penalty right there... What type of pen though? Would that have mean't Vettle would have got third?
How come Hamilton didn't have to yield when defending from Ricciardo after he straight lined the chicane? Ok, he didn't straight line it that much, but I would say he didn't make the corner whilst defending and potentially gained from it.
Agreed. Regardless of what strategic SNAFUs RB has pulled on Ricciardo so far this year, calling him into pit when the tyres are still in the garage is totally unacceptable.
Has there been any word on what happened? I wondered whether there was a last minute change of mind on which tyres to use or something?
I read that it was a last minute change on what tyres they wanted to put on. Christian Horner also said that the garages were too small and on different levels so it was harder to get the tyres there quickly. Which is why every other team suffered this same issue. Oh no wait...![]()
1) Perez on his out from the pit was all over the yellow line, and I am sure he actually crossed it. That's a penalty right there... What type of pen though? Would that have mean't Vettle would have got third?.
Maybe they deemed the wet pit exit, and with coming out on slicks, it was difficult to avoid the line. They've been pretty slam dunk in the past when it comes to line breeches so it seems odd they would miss this, unless they had a reason like stated.
2) How come Hamilton didn't have to yield when defending from Ricciardo after he straight lined the chicane? Ok, he didn't straight line it that much, but I would say he didn't make the corner whilst defending and potentially gained from it.
The offence is to leave the track and gain an advantage. When he entered the corner he was ahead of Ricciardo and after missing the corner he was alongside, so he didn't gain any advantage, he lost time from it.
As above, Hamilton was in Rosberg's dirty air, which meant a little less cooling for the brakes, keeping them and the tyres warmer. When Hamilton had to warm his tyres and brakes himself later in the race he couldn't do it either until the track was much drier.
If I was Rosberg I wouldn't have let Hamilton past. He was looking almost a sure bet for the WCC until this weekend.
I don't think that has been discussed in this thread. Would Hamilton if the positions were reversed? Admittedly Hamilton has less to lose this season disobeying the order.
Tyre wear isn't an issue at Monaco, it's thermal degradation (normally). There was no tyre damage at all in the race - even the wet tyres held in and Hamilton's looked almost as good as new when he stopped, even after running around on a dry track. There weren't even any marbles this year, that's how little the tyres were wearing or graining.The dirty air would have meant that Hamilton's car was sliding around more, which doesn't warm the tyres, but damages them instead. As for a slight loss of cooling air, that won't help raise the brake temperature by the 100 or so degrees required for them to work.
The problem with the tyres later in the race was due to the compound being completely unsuitable for the track temperature, or have you forgotten that the car was running the purple ultra softs which actually require a hotter temperature to operate correctly than the super softs.
Even if Hamtilons's brakes were only 10 degrees higher than Rosberg's he can brake harder, getting more temperature, then at the next corner harder again and so on, gradually ramping up the temperature and thus that of the tyres. If Rosberg wasn't able to get over that hill then he was only going to go slower until was on a more suitable tyre and able to stress the brakes a bit more.
Hamilton is a better driver in the wet than Rosberg, but he's not 5 seconds a lap better.
Ooh, someone's get a bee in their bonnet.
The ultra-softs do apparently like a higher temperature for peak performance, but presumably the reason Mercedes chose them is because they wouldn't be able to get the other tyres up to any temperature anytime soon, let alone reaching the peak operating temperature. The other teams that chose the ultra (albeit only the lower-end teams) didn't seem to have the same problem or not to the extent Mercedes did of losing 10 seconds a lap initially.
