- 18 May 2010
- London
Looks at prices!
It's underkill in most situations if anything.
How so? Are you referring to the Xeon comparisons?
Cheers![]()
So...will these new CPU's work on the original X99 motherboards?
Say if you had a 5820k, could you get the new top of the range chip to replace without upgrading the mobo?
Correct however you WILL need to update your bios before removing the 5820k
I think the only question here is, if someone was in the market for a 5820k are they better off going and buying a 6800K instead.
Considering the 6800k looking to be around £60 more on launch for next to no improvement it's a hard sell over the 5820k
Yeah, I was going to get a 6800K today but got a 5820K instead after looking at the gaming benchmarks which showed practically no difference. Couldn't justify spending the extra money for that.
So £2K for a 6950X+X99+DDR4 excluding a decent GPU.
Or £1k for 5960X+X99+DDR4!
I think I would buy a 5960 system its not like anything really needs 16 threads let alone 20! I knew Intel would find a way to sting the consumer though as it re-uses the same 2011V3 socket they cannot sell yet another motherboard variant so they price gouged the CPU![]()
It is as a decent X99 motherboard is around £350-400 + DDR4 + 6950X=£2K.Not quite 2k for the 6950x setup unless you go to town with the Mb and ram, cpu's on pre order for just under £1400...
https://www.overclockers.co.uk/inte...rocessor-retail-bx80671i76950x-cp-617-in.html
You would not get a 5960x setup for 1k at retail prices either!
(the 6950x is still very expensive compared to haswell-e cpu's)
5960X can easily be had for around £780 + DDR4 + X99 cheaper motherboard=£1K
