Ok this all made no sense to me which means I have been out of the loop too long.
Can you please help bring me up to speed on whats been going on? Is this all to do with Engineers I take it?
As already linked, checkout the Inara link, that will help.
In summary:
- There's a whole bunch of "engineers" being introduced. My understanding is circa 30
- Each engineer can "modify" one or more components on your ship (e.g. FSD)
- You'll see invites from 4 or more engineers in your communications tab
- Additionally, open your screen for status and in the bottom right corner is a box labeled "engineers". Go in there and it'll help you find their locations. Most are a good distance away (at least for me). Closest for me is 5 jumps in an Asp
- Each engineer has a requirement that needs to be met for your introduction, e.g. give them dosh, data, components, materials etc
- Once you've been introduced you then get the option of which component to update
- to update a component you need to have unlocked data. You do that by scanning either ships or ship wakes. My suggestion is just scan EVERYTHING, whenever you have the chance
- If you have the data for a component change, then you can see if you have the required materials. If you've previously been on planet, you might already have some. The Inara site gives you the breakdown of what's needed and good places to find.
- Once you have the requirements, you can try to make a build, at which point RNG kicks in and you "might" get something good. If you say no, you still lose the materials for that try out, but it doesn't stop you having another go.
- As you work more with that single engineer, your "rank" with them improves, unlocking better options. Just keep going seems to work
Hope that helps.
I grabbed enough scans and materials in roughly 4 hours to allow me to make rank 3 with one engineer. Just need to grab some more arsenic. I'm looking to update the range on my FSDs first. Apparently it's possible to get upto +45%, which I'd love to have.
