- 30 Sep 2005
a 10 year old Vauxhall Nova with NOS can keep up with a Ferrari, doesn't mean you'd buy a Nova!
Didn't you not catch what I said about when used in real-world situation?
In real-world gaming, nobody would be running the card in open-air, nor would they put up with the noise of 100% fanspeed (even headphone users would not risk running fan at 100% speed at all time as it will probably wear the fan bearing much quicker and shorten the life of the fan proportionally)...hence why I pointed to 3rd party card with good cooler (i.e. Gigabyte Windforce etc), as they are likely maintain those speed without having to run the fan at speed as loud as a hairdryer.
In my opinion one needs to be retarded to compare Single card vs Crossfire or SLI.
Ye its can be on pair or faster solution WHEN IT ****ING WORKS.
SLI and Crossfire Reality:
- Does not work in most new games for weeks or months after they come out sometimes NEVER...
- Does not work with current VR stuff
- Does not work good with 3D gaming in most cases
SLI and Crossfire is for people that play games like:
3d MArk
Unigine heaven
Unigine valley
o wait..... them are not games.....
I had it and i was spending more time fighting to get **** running without micro stutter or working at all than playng the freaking games... Every game had its problems bigger or smaller :/
You are quite right, and as I said before your 1080 is not doubt still a very quick card, but what I was referring to is the majority of the benchmarks are showing the 1080 performance at 2150MHz+, and it is at a speed that I doubt the FE 1080 can maintain without having the fan pushed to very loud level.It is real world
I have gamed for a few hours and with 60-65% fan profile in witcher 3 inside my case the card is hovering between 1950-2050 mhz. As I mentioned it is not and will not be as quiet as aftermarket coolers but this time around its not quiet as loud as the Titan X reference cooler and I do not really have an issue pegging fan profile to 60% and game away.
Not advocating most people pick a Aftermarket 1080 over FE, but rather its not quiet as bad as one may imagine seeing the horror stories of the card thermal throttling anywhere.
the majority of the benchmarks are showing the 1080 performance at 2150MHz+, .
If people want the same performance quoted by the reviews at 2150MHz+ clock, the cards with custom cooler is far more likely to be capable of that without killing someone's hearing...that's all I'm saying.
LMAO really? I take it you never owned a ref 290x?
I own one, and the highest I could bear was at around 55% max...which is while I think people are mental to think that over 65% on the FE 1080 acceptable for everyday usesLMAO really? I take it you never owned a ref 290x?
I own one, and the highest I could bear was at around 55% max...which is while I think people are mental to think that over 65% on the FE 1080 acceptable for everyday usesEven IF the FE cooler's rpm is lower and that its 65% is same rpm as the 55% on the 290 cooler, it still doesn't making the FE cooler noise level bearable, if going beyond 65%.
For reference, my 290x's cooling has gone from the blower cooler to a Icy Vision Rev2 cooler, then finally now with a Corsair H105 AIO with the HG10A bracket![]()
Nope, I have not been in disagreement with Radox, and basing on the information that he's given, the average of 2000MHz max clock on that 65% fanspeed is probably what most people will get.The ref 290X cooler was far louder than my Titan X ref cooler and I wouldn't want either running at 100% but Radox has told you his experience but you can't seem to accept that for some reason?
http://www.3dmark.com/search?_ga=1....00?minScore=0&gpuName=NVIDIA GeForce GTX 1080
Just seen some 1080sli scores on 3d mark page, seem to be in the 10-11k range. Top graphics score (number one) is 11038. Doesnt seem much of an improvement for 980ti sli users
First in table as of today (this is NOT my score)
SCORE
11 038 with NVIDIA GeForce GTX 1080(2x) and Intel Core i7-5960X
Graphics Score 11 580
http://www.3dmark.com/fs/8643474
And score compaired to mine.
http://www.3dmark.com/compare/fs/8631429/fs/8643474
The increase in physics score is decent at least.
