Caporegime
- 18 Oct 2002
Ok thanks for the info Radox & Tyler, looks like I'm holding out for the Ti then as Division is all I'm playing at present!!
My EVGA FE turned up yesterday. To be quite honest I'm just glad to be gaming again, but the card is still currently on the stock blower, running aggressive fan profile (70% tops). 65c at 1950Mhz. Just eats 1440p no problems what-so-ever.
Those temps and that clock sound good. What is the noise level like at 70%?
Is anyone able to confirm just how the voltage offset % slider works in afterburner, it doesn't even seem necessary at around 1950mhz core boost? Also, can the lighting of the various cards be turned off fully via geforce experience, if not, is there a solution using afterburner?
1080 does have smoother frame pacing and frame-timing than the 980Ti. That will add to the smoothness of the game.
I have similar issues at times with my Ti's on the division. See what its like when i receive my 1080's on monday.
Lighting on standard FE cards can be managed by Geforce Experience. Using Precision X OC (EVGA's OC Tool) I can see there is a zone it it already set up to manage LED's for the aftermarket EVGA cards. Imagine there will be something similar for the others and recall ASUS is using Aura for their cards.
Also on the matter of SLI, I do think as per that youtube article the LED bridges available are already sufficient. When I use an old flexible bendy bridge I get a warning message in the control panel.
Said message not shown with my two LED bridges (EVGA v2 and Nvidia bridge)
How long do you think an overclocked 1080 will likely last?
As long as you aren't pushing it to the absolute limit of temps or volts then it will last just as long as any other card.. I push my hardware to the limit for benchmarking but for everyday gaming I dial it back a fair bit. My last hardware failure was an ATI 9800PRO whenever they were relevant.
Would doubt there's much difference if any between them, multi gpu is never as smooth as a single gpu, they can probably show minuscule differences on a graph but in terms of feel, probably the same.
Looking good. Certainly interested in seeing the OC SLI vs 1080 OC though. Or even 1080 SLI OC vs 980Ti SLI OC.
Thats odd. I dont get that warning and I am only using a cheap flexible bridge that came with my mobo.
Bit of a pointless comparison really, I don't understand these overclocked vs stock benches...O/C vs O/C is what is relevant
When it arrives do I put you on TROH or would it be easier to have a separate one just for you.![]()
Any 1080 that have 2 hdmi outputs. Looking at connecting one straight to my 4k TV and If possible using another to output audio through hdmi to my non 4k amp. Don't really want to fork out for a new amp if I can avoid it. Is that actually possible if a card has 2hdmi outputs
