The mk2 mps worth around 10k.
mines worth around 7.5 - 8k
He offered me £6k for mine. I just laughed and left.
According to Parkers yours is worth £6,240 as part ex assuming 50k miles. Don't think his offer was too unreasonable really.
Put the PDC fuse back in, yep, still constant beep in reverse.
Took the fuse out again.
Who needs parking sensors anyway?
You won't reverse over yourself, because the car will have gone backwards before you even get out of it
But yes, already checked, all sensors are ticking at the same rate. Tapping sensor 4 results in it intermittently working, then going constant beep again the next time I drive. This kind of indicates a dodgy connection to number 4 that goes on and off with vibrations as the car is driven I guess.
Virtualisation always worksIf you're actually bothered then drop me an email, happy to help you get it working
