Hi all,
I will be upgrading my supercomputer in the next few days, with two 1080s, new board and new CPU.
I am aware of other threads, but I am really only considering those two CPUs:
5960X and 6900K. OC-wise the 5960X can go up to 4.6 and the 6900K to 4.4 as far as I'm concerned. What does it depend on? Would a £500 motherboard make a difference comparing to a £250 motherboard? Would (water)cooling MOSFEts and the Chipset make any difference?
Both have 8 cores, but the biggest difference I am seeing is transistor's size, 22 and 14nm.
My system is water cooled, with a massive radiator from a car
if this makes any difference.
I am using my PC for a lot of stuff.
Which one should I go for? And what would be your reason?
