I'm thinking of getting a dual channel pre amp for vocal ,guitar and drum overheads...
The pre amps on the Octa Capture are excellent but very clinical...
Should I take a stab at the Art Digital MPA II ? And swap the tubes ?
Ideally I could use Spdif out and use the Spdif in on the Octa capture bypassing the Roland pre amps?
Or doesn't it matter so much if I use a line out of the pre amp into the line in if the Octa capture with no gain used?
Lowe over to you
http://thelittleredlight.com/gear-reviews/can-you-tell-a-100-preamp-from-a-4000-preamp/
Lowe over to you
