- 30 Nov 2011
others believe
sounds legit
others believe
1266 is boosts and 1400 is boosts as well, i am missing something?
I told you this card would eventually end up faster than a 1080 eventually. lol
Anyways, really wish that we could get some solid gaming benchmarks. I could go a couple weeks without my 970 if I could be sure the 480 will be the card I want it to be.
http://www.overclock.net/t/1603257/jd-xfx-rx480-8gb-pictured-with-official-specifications
Incase you miss the source link. http://item.jd.com/3152734.html
New info?
XFX branded 480 with specs etc and pics. Clocked at 1288 stock speed apparently, 1999 yuans which is about 212 in pounds.
No but my point is the base clock is 1080Mhz so if it boosts to 1400 or even 1500 on air then thats a 40% overclock and people shouldnt be expecting more.
look at the 980ti. Base clock depending on model was 1000 to 1200 and set boosts were between 1100 and 1300.
Of course people could then manually overclock them and get boosts over 1400Mhz and some lucky people managed the magic 1500Mhz.
What makes you think the 480 will be any different? Its standard base and boost clock is very similar to the 980ti. Nobody said with the pre oc 980ti, "omg thats a poor boost overclock as it came set at over 1300 and I only made 1450."
if it does 1500 on air then thats a 39% overclock from the base and I would be more than happy with that.
i just found this, extreme mountains of salt required before viewing, i actually let out a little laugh
http://i.imgur.com/c9ZRY2v.jpg
With Nvidia we never go on base clocks for the overclock. The boost clock is usually used for a more accurate assessment of the overclock. A gtx980ti boosting from stock 1200 to 1500oc is getting around a 25% overclock and will receive the boost in performance with that. If the base clock was 1000 and you overclocked to 1500 and called that a 50% overclock you will receive nothing like 50% of the performance as at stock you were getting around 1200mhz constant.
With the node drop hopefully the 480 overclock's better than the gtx980ti or at least on par as it should be pretty fast either way.
A real 50% overclock was the 7950 stock at 800mhz and overclocked to 1200 mhz. The gains were massive.
I checked a few reviews of the stock card and those that mentioned it said the stock 980ti was running around 1200, so i always used to use 1200 as my baseline, so a 25% OC was aroubd 1500 in my book
I would do the same for the 480, so if in tests it usually runs at 1266 i would use that as the baseline. Otherwise you are calling something a 40% overclock but only getting a 10% gain from stock, which just sounds wrong.
I see your point but 980ti were made with boost clocks ranging from a lowly 1075 to 1344. if both managed 39% overclock and the more epensive second card only did 12%. AFAIK stock boost for the 980ti was only 1075Mhz?
Also http://videocardz.com/61147/xfx-radeon-rx-480-pictured-features-1288-mhz-clock
New info?
Getting excited here. That's a very nice looking card indeed.
1266 base clock? Niiiiiiice, can only imagine what the AIB OC'd ones will be like![]()
It will look like 1306Mhz
Like the overlocker's dream Fury X OC editions hahaha.
I really hope Polaris delivers; the Hype rollercoaster is constantly going up and down.
