- 24 Jul 2009
- Lost in Alps
Thinking of going for an MSI Gaming X, appreciate thoughts, OC clocks, temps from owners. Thanks!
Quieter then G1, Strix (that is not hard at all actually), Inno X3. Good choice. Possibly GLH might be even better but it is bigger and has less warranty.
Strix noise levels under load is 40 dBA, G1 at 41 dBA, MSI 1080 at 39 dBA and Palit Gamerock Premium at 38 dBA (guru 3d) .. their lowest noise level on their chart is 38 ..
And that's really all just in the margin of error of test conditions.
Really there's no real-world difference worth mentioning between these cards.
Based on current reviews I would choose MSI G1 or Palit GameRock / Gainward GLH. If you do not want to OC probably G1.
cheers
So after using the GLH for almost a day I can confirm that with the default fan curve it sits idle quite high at 38 degrees as it turns off the fans but doesn't go higher than 70 under load.
I have finally settled on +60 on the core and +350 on the memory which is quite good considering the card was initially factory overclocked quite high. I have seen it boost as high as 2113mhz.
As for coil whine I have not heard a peep from the card and at load it is only running at 48% according to MSI Afterburner so she is whisper quiet.
The only game I have played is Overwatch and with all settings @ ultra/epic playing at 1440p on a 100hz monitor I haven't seen it go any lower than 90fps.
Quite happy overall I must say and glad I made the switch from the EVGA SC.
Matt.
