** OcUK HAS 21 CUSTOM GTX 1080 MODELS READY FOR PRE-ORDER !! **
BTW, "binned" is not a literal term. It means that the GPU has been selected specifically because it holds decent clocks. Binned is a good thing:p
Yeah but if the chips are not selected and that it is enough to overclock manually on afterburner for the same result (noise/ temps), no interest to pay more.
The MSI is at the same price with the golden sample.
Historically the GLH models have had binned chips, hence their high clocks but seeing as all these card look to be pretty much the same you could certainly take your chances with the base model and clock it up.
If you want, I'll pull the BIOS from my GLH when I get it (assuming I can) and upload it for you to try. Might just get a nice free OC!
I could show you another test in which Strix is 4db louder in gaming then MSI Gaming X. 4db is big an easily noticeable.
In the end the question is does it matter to one? If it does one will find the quietest card (measured) as I did. If it does not then yeah why bother but there is no point in denying facts.
I have few 0db rigs at home. My gaming rig will not be 0db. That is not possible at performance level I am aiming for but it will be as quiet as possible using air cooling and it means that every little thing counts, every single fan, and every last DB I can shave off.
Cheers
Read my post again, I'm not saying the Strix isn't louder than the MSI or G1, what I'm saying those 2 tests are very poor for a real build comparison. Making purchase judgements based on them may not be ideal.
An open bench isn't going to give you an accurate reading of noise in a normal case build, you aren't going to get the ambient heat build up that you would in a case which will obviously require and result in a faster fan speed.
And the video doesn't tell us anything as we don't know what they are doing in their "gaming" test (if they are even gaming, they could have just altered the fan speed %) or what fan profile they are using and again it needs to be in a case to be of any use to most people.
If you're system is an open bench then these tests may be of real use.
Note my build is a quiet build, you'll notice the sound reducing case and very quiet fans. My G1 doesn't sound anything like the video even with the side panel off and my ear 6" away from he card, which suggest their "gaming" test was a fake or they have a poor card or high ambient room temp. :)
IMO asus really messed up: Palit and Gainward have their 3 tiers where the chips can fall in (as MSI),
Asus going off the bat with the unmatched 1936 advertised boost for their only AIB card (the other is the gigabyte, but they have the G1 for worse chips)
are essentially forced to announce soon a lower clocked model as well as made it almost impossible to come out with a Matrix card in the future.
This has happened with most manufacturers (Inno lowering the clocks for their V2 of the cards), I guess Nvidia yields are not as good as they all thought.
Another reason might be that with Boost 3.0 making manual overclocks less impactful, they all had to push the cards further to make their models seem more valuable.
Really happy I went FE Now rather than waiting
I can easily see 1800+ constant on my card without oc
So a ab card is only getting 50mhz difference and with a 10% increase in fan speed seeing 1900mhz at 78c
Guys/Gals ............
Can someone settle my thinking on this ............
Pre-Orders, obvious what this means lol
But ..............
Suppose they show cards in with decent amounts (10+)
Am i correct in thinking that the stock goes striaght to to pre-ordered, or is there a likelyhood of me driving the short distance as i usually do to try and snag a card ?
I think it's gonna be the former ?
Cheers
Hi there
Here is what were expecting this week:
Asus 1080 FE - 100pc (plenty available)
Asus 1070 FE - 100+ (plenty available)
Asus 1080 Strix OC - Upto 50pc throughout this week, fulfilling backorders only.
Asus 1070 Strix OC - Maybe 50pc by end of week but unlikely
EVGA 1080 FE - 100+ (plenty available)
EVGA 1080 SC - Maybe 50 late this week and fulfilling backorders
EVGA 1080 FTW - Early July
EVGA 1070 FE - 200 this week, stock available
EVGA 1070 SC - Unknown
EVGA 1070 FTW - July
Gainward FE - Plenty available now
Gainward Pheonix - NO ETA
Gainward GS - 10 today/tomorrow, stock available
Gainward GLH - 10 today/tomorrow, all pre-sold
Gainward 1070 FE - This week!
Gainward GS/GLH - Maybe late this week!
Gigabyte 1080 FE - Plenty in stock
Gigabyte 1080 G1 - Around 100 this week, plenty available
Gigabyte 1080 Extreme - Late / early next week
Gigabyte 1080 Extreme PP - 20 this week, nearly all pre-sold
Gigabyte 1070 FE - 1000 this week, plenty available!!
Gigabyte 1070 G1 - 100 this week, plenty available!!
Inno3D 1080 FE - 20pc this week, available.
Inno3D 1080 X3 - 10-20pc this week hopefully, all pre-sold
Inno3D 1080 X4 - 20pc this week, available.
KFA 1080 blower - 100pc next week, available
KFA 1080 EX OC - 50pc next week, all pre-sold
KFA 1080 HOF - Early July
KFA 1070 blower - 1000pc next week, loads available
KFA 1070 EX OC - July
KFA 1070 HOF - July
MSI 1080 FE - Plenty in stock
MSI 1080 Aero - End this week, all pre-sold
MSI 1080 Armour - End of this week, all pre-sold
MSI Gaming X - Any day this week, all some left for free stock
MSI Sea Hawk EK - IN STOCK EXCLUSIVELY AT OcUK RIGHT NOW!
MSI 1070 FE - In stock, more en-route
MSI 1070 Aero - End of week, some available
MSI 1070 Armour - End of week, some available
MSI 1070 Gaming X - 500pc this week, plenty available
Palit all models, very small amount next week, all pre-sold
PNY - Some next week
Zotac 1080 FE - Plenty in stock, 5yr warranty, best FE card to buy!!!
Zotac 1080 AMP - 20-50pc due this week, all pre-sold!!
Zotac 1080 Xtreme - July
Zotac 1070 FE - This week hopefully
Zotac 1070 AMP - Next week!
Zotac 1070 Xtreme - July
If I missed any cards just asked, but I think I covered them all, all manufacturers worked 24/7 over the weekend producing and shipping cards, so we hope by the end of this week a lot of backorders shall be cleared and cards in stock.
If I missed anything just ask guys, but because OcUK has more brands and SKU's listed than any competitor it is hard to keep up, the advantage however is were getting more than double the stock, even triple compared to our other big competitors. :)
Infact I do not have it confirmed but I believe OcUK is the no.1 reseller in whole of Europe for 1080, which is an achievement I am very proud off because UK TAM is a lot smaller than some of our European competitors. :)
But ..............
Cheers
If it shows a stock level of 10+ it means all pre-orders have being allocated and shipped out, the stock level is actual free stock, so if you order a card showing in stock or 10+ you will get the card next day as long as warehouse ships that day and the courier does their job correctly. :)
