Good point but i will be surprised if it will be that long
14 days at most will see
had a friend recently with a sound card no turbo service and turnaround was 12 days yes i know it was not a gfx card but still
Don't forget...
28 working days.
That's basically up to August...
Oh believe me it can easily be the full amount as they are known to drag their heels if they feel like it.
Stick a new fan on or sell it as it is.
Seems so silly. Because if they do. It just means they have lost a customer for life in me. I can't imagine why they would intentionally p*** off their own customers?
Sadly I thought I would be getting the OCUK "Turbo" RMA service. Apparently that doesn't cover this so the card has been sent to ASUS. I wouldn't have sent it to OCUK if I had known it would be sent off to ASUS.
Sadly I thought I would be getting the OCUK "Turbo" RMA service, so I have already sent it to OCUK. Apparently that doesn't cover this so the card has been sent to ASUS. I wouldn't have sent it to OCUK if I had known it would be sent off to ASUS.
Items returned for repair/replacement are sent to the manufacturer under warranty and the turnaround time can vary. Overclockers UK will try to return the items to you as soon as possible. If we are unable to return the items to you within 28 days, we will give you the option of a refund.
Depending on the age of the items, the refund may include a deduction for the length of time you have used them.
https://www.overclockers.co.uk/returns
That sucks, OCUK being a bit nasty there. I hope you get a quick turn around but Asus warranty is nothing to behold speed wise unfortunately.
I've had a good experience with my swift. Exchanged at the door. But it did take a few weeks to get it sorted.
Looks like I'm in the same boat, one of my strix cards **** the bed, refuses to install drivers and the other night I was getting a load of weird glitches on gtav. Presumably the ram has had it, it can still get into windows at an incredibly low and blurry resolution but that's the limit of what it can do.
Could just be the drivers. DDU them. I've had similar problems with my Ti's with random artefacts and crashing. Was locked to crazy core clock for some reason. DDU and re-install fixed it.
