Request: 980ti SLI Benchmarks
6 Jan 2013
Rollergirl
TLDR:
Early indications are that bandwidth does make a difference in applications that have good SLI scaling, and can be as much as 10% which equates to a decent overclock to your GPUs
We've been looking at numbers in the 980ti owners thread as one of the guys is considering SLI. I ran some benchmarks for him, but we're now discussing the difference 6 cores, 40 lanes and resultant PCI-E bandwidth makes. I've also seen this discussed elsewhere when people have been trying to decide which hardware to buy. Some say it makes a difference, some say it doesn't.
Could we settle this in this thread? :)
It would require someone with 980ti SLI driven by a 4 core i7 and a mobo supporting only x8/x8 bandwidth. Bench the following games @ 2560*1440 with your cards running 1418/3500.
- Added : As long as it's a pair of 980ti then it doesn't matter what the CPU/Bandwidth - it's all relevant.
ROTTR
Far Cry Primal
Dragon Age Inquisition
Metro Last Light Redux
Firestrike
Firestrike Extreme
Firestrike Ultra
Heaven
Is there any way I could force my cards to x8 bandwidth? - PCI-E Gen 2 in BIOS
(Remember, GPU's must be 980ti @ 1418/Stock)
Resolution should be 2560*1440 where it's optional.
ROTTR Settings:
Heaven Settings:
Valley Settings:
Far Cry Primal Settings:
Dragon Age Inquisition Settings:
Metro Last Light Redux Settings:
Current 980ti SLI (1418/stock) Leaderboard :
ROTTR
  1. String (5930k @ 4.4GHz x16/x16) - 100.25
  2. MrKambo (4790K @ 4.75GHz x8/x8) - 91.36
  3. String (5930k @ 4.4GHz x8/x8) - 90.48
Far Cry Primal
  1. String (5930k @ 4.4GHz x16/x16) - 68
  2. String (5930k @ 4.4GHz x8/x8) - 68
  1. String (5930k @ 4.4GHz x16/x16) - 112.7
  2. String (5930k @ 4.4GHz x8/x8) - 105.9
  1. String (5930k @ 4.4GHz x16/x16) - 82.18
  2. String (5930k @ 4.4GHz x8/x8) - 78.77
Firestrike
  1. String (5930k @ 4.4GHz x16/x16) - 24248
  2. MrKambo (4790K @ 4.75GHz x8/x8) - 22931
  3. String (5930k @ 4.4GHz x8/x8) - 22632
Firestrike Extreme
  1. String (5930k @ 4.4GHz x16/x16) - 15106
  2. MrKambo (4790K @ 4.75GHz x8/x8) - 14861
  3. String (5930k @ 4.4GHz x8/x8) - 14082
  4. Awahwah (4690k @ 4.5 x8/x8) - 13487
Firestrike Ultra
  1. Gabbatek (5820k @ 4.2GHz x8/x8) - 8469
  2. MrKambo (4790K @ 4.75GHz x8/x8) - 8376
  3. String (5930k @ 4.4GHz x16/x16) - 8347
  4. String (5930k @ 4.4GHz x8/x8) - 8065
Heaven
  1. String (5930k @ 4.4GHz x16/x16) - 2730
  2. String (5930k @ 4.4GHz x8/x8) - 2763
Valley
  1. String (5930k @ 4.4GHz x16/x16) - 4164
  2. String (5930k @ 4.4GHz x8/x8) - 3861
This is my result for ROTTR
4790K @ 4.75GHz
980Ti SLI @ 1418/3500
My minimums suck real bad for some reason, might have to investigate that!
If you can limit PCIE to gen2 in BIOS would that give a similar effect ?
I tried Gen 1 and Gen 2 but still getting x16.
4790K @ 4.75GHz
Interesting. Over 10% FPS difference and as you say a big difference in minimums. The minimums is something I think a lot of benchmarks and reviews don't take into consideration.
Could you run the three Firestrike benches at those settings (Normal, Extreme and Ultra)?
I can't play benching till the weekend now, but ill spent the afternoon on Saturday going through all my bench runs.
I've got a few games with built in benchmarks, i feel thats more of a accurate representation.
But ill stick to scored benchmarks if that what you need.
