it might not be the battery as the batteries on mine don't get pushed down at all. It might just be the threading on your cap and mod.. try screwing and unscrewing the cap on and off a few times to make sure it's not cross threading and jaming.
It's better if you get it all seperate personally mate.
I'd highly recommend you pick up a set of scales and mix by weight as opposed to volume, it's a hell of a lot easier and you hardly have anything to clean up.
Scales - http://www.amazon.co.uk/dp/B00ME8VI34
PG/VG and Nic all from Darkstar Vapour - http://www.darkstarvapour.co.uk/
Concentrates are a personal choice, I mostly use FlavourArt, Capella and TFA (The Flavour Apprentice) - http://vapable.com/. Just take note that some contain known 'nasty' ingredients; Acetoin, Acetyl Propionyl and potentially Diacetyl. For the record FlavourArt (FA) use NONE of these ingredients. Stay away from Flavor West concentrates!!
Bottles - https://www.ibottles.co.uk/products...t-plastic-ldpe-dropper-bottle-stubby-tip.html
I'd probably pick up 2 of these to hold your PG and VG. 250ml ones are 45p each - choose the 24mm Natural Nozzle and Captive Cap option.
Recipes: http://www.lediypourlesnuls.com/ - http://vapingunderground.com/forums/diy-e-liquid-recipes.50/ // depends what type of flavour liquid you're after, but I'd probably look at making some fruit ones to start off with, they require very little steeping time (usually shake & vape!). I made this the other day which I'm currently vaping right now and it's lovely.
Recipe calculator: http://e-liquid-recipes.com/create
That should be everything to get you set up mate, if you need any help gimme a shout.
After a bit of advice chaps.
I fly out to Portugal tomorrow and have not flown in about 10 years. I've also never travelled with vaping materials. I'll only be taking a couple of 50ml bottles with me, but as I make my own they'll just be unmarked bottles and don't fancy causing a fuss at security carrying unknown liquids.
I know normally you have to put liquids in your suitcase unless they are under 100ml (I think) so am I ok taking them in my hand luggage?
Any advice appreciated if it avoids me having some custom officer's cold, rubber gloved hand inserted in my cavities![]()
When I flew to and from the states last year they weren't bothered by labeling, they put the bottle in some scanning machine to check it and that was all.
Make sure to empty your tanks before flying though, the pressure causes them to leak![]()
[TW]Sponge;29687614 said:Capella V1 Custard has 'nasties' in it. But by god it's so nice. Anyone tried V2? Much difference?
I've been vaping for a couple of years now and have happily settled on the aspire K1 clearomisers, aspire bvc coils. However, I've got a trip coming up shortly that will mean no chance to charge batteries for days at a time. I have quite a few 18650 batteries spare so want to buy a new vapouriser that can take these instead.
I'm not clued up at all about the different types of vapouriser but I've stumbled on a review of Kanger Topbox Mini Kit. This appears to take a single swappable 18650 battery fine. Is this any good? Are there any better I should think about? A bit more vapour than the K1 produces would be good, but I've no desire to vape like a dragon!
I like my current setup because it's very easy, I just buy replacement coils every so often, so a new vapouriser has to be the same. I don't want to be making coils or anything that technical.
Any advice/thoughts would be welcome
Someone private messaged me with regards to my progress with the Rejuiced complaint, can't seem to respond direct so...they give me an apology and an assurance they would investigate and put it down to a mixing issue. They sent me 4x30ml bottles as a gesture.
Waiting on an order from Jackamoo juice, my first try. Website is god awful but juices came recommended from OCUK.
Still very much like Rejuiced, will still be using them.
