The Dall Estate is nice, had a place up there for just over 3 years. I'm not that far from the zoo, a few streets behind the BBQ chippy.
I'm assuming you probably won't be far from there. Apparently they changed skin so soft, took out whatever it was that was working against midges. Probably halved their sales in Scotlands![]()
I'm gonna try and gather everything up that I need for the trip,
I'm slightly abusing your image Darg, using it as a quick check to see if I've missed anything
god starting at 0 for camping equipment leaves a dent in the wallet haha
Glad I can help Giraffe
It certainly does, I went shopping with three friends that pretty much had to buy everything and another friend who had everything she needed already. Me and her spent about £50 between us on gas and some other bits, the other three spent £1200 between them, it was painful to watch. In fairness they did go a bit overboard on getting super high quality stuff for one trip. Just going to have to make sure we go on more so they get their moneys worth!
That's where we were in Rannoch. Well worth the slog through the bogs on the way up.I'm assuming you probably won't be far from there.
I know where the BBQ chippy is. I'm just at the start of Carrick Knowe behind the Forestry Commission building.
Not too far from there. Another good place to camp is where the two small lochans are, about 1.25 miles up the hill from the school. Or head up Glen Lyon footpath, plenty of open ground and you can see Ben Nevis in the distance, not many tress for canopies though![]()
No way is a foam mat as comfy as a bog standard thermarests. Yes it's more expensive but I've had mine for a fair few years (and borrowed my sisters prior to that) and never had a leak. It's smaller as well as way comfier than a foam Matt. If cost is an issue then the foam may be the best option, then you can upgrade later.
Anyone else constantly ready OP's name as GiraffePenis?
That's one of the packs I have and it's great.. My only gripe with it is that the hip belt isn't detachable!
If you haven't bought yet, I'm going to throw in a budget vote for Alpkit. I've got their Gourdon 30 litre roll top drybag which I bought for occasional hauling on my bike, but I actually use it quite a lot because it's such a useful size. Their other kit gets good reviews on the hiking/touring section on a cycling forum I use. Can't tell if they do a bigger bag because their site is a bit difficult to navigate...
https://www.alpkit.com/
